GenevaDirt , haven't heard from you .Did u get my number ??
Easiest way to replace clutch ??
the B3 can be lifted out by hand but it would be a royal pain to line it back up when re-installingOriginally posted by bhazard View PostHow much does a B3 weigh? Pull it by hand!
RIP 90LX
Had mine out....picked it up with my hands and set it back in place while the wife ran the passenger side craddle bolt in....once in...I dropped the tail end down onto a block.Originally posted by Damkid View Postthe B3 can be lifted out by hand but it would be a royal pain to line it back up when re-installing
IMO...there is no reason to consider pulling the block to change a clutchJoe Lutz
The SKATE ..... 1992L 5spd
X2Originally posted by jglutz View PostIMO...there is no reason to consider pulling the block to change a clutch
Especially since the trans is relatively easy to remove, and unbelievably light.Axlander9289, brother of ThisVelologist
Festivas past:
Aqua '92 Festiva L - Sold "Dale"
White '89 Festiva L Plus - RIP "Dudley"
White '93 Festiva GL - Sold to thisvelologist "Frito"
Red '91 Festiva L - Sold to Louieisawesome "Geraldo"
Current Fleet:
Aqua '93 Festiva L with Aspire brakes "Dale Jr."
Black and White '93 Festiva GL Sport (White alloys and spoiler are long gone) "Blues-tiva"
White '15 Ford Transit Connect
as stated....I prefer not to lay on the floor or in the dirt and gravel messing with the tranny when I can remove some bolts and wires and use a cherry picker to pull the engine out. Then when it is out you can clean the engine....go over it and replace any gaskets with ease. Change the water pump...ect.... To me it is much easier to work on that stuff while it is hanging out in the open."FLTG4LIFE" @FINALLEVEL , "PBH"
i agree with genevadirt... i dont want to roll around on my back, but then again i do this stuff for a living and am spoiled now. i dont even change my oil on the ground. these cars are so light that every thing is easy, compared to other cars. if you have air tools and such, and a garage, then its all a matter of personal prefference. although it would be good for a novice to do the tranny on there back. it kinda weeds out those who wouldn't last any way. kinda like a right of passage.Neil
Jesus loves me. This I know.
93 L track prep in progress
88? Parts car-sold
91 L B6-me f25mr-soon to be ???
86 b2000- pisses of HOA-sold
1997 k1500 suburban- kid hauler/GAS hog
Both ways are not that bad. I prefer the tranny way myself because I can do it in an hour. If you pull the engine, you will be dealing with more wires, but each one has there ups and downs. If you are getting help, do it the way the other person wants to do it. If you decide to pull the tranny, you could use a car jack and a block of wood to support the engine. If you do it this way it helps because you can then also lower the engine to make tranny removal and installation easier.The Festiva Store
Pulling the engine requires pulling these extras
Coolant lines (4X)
fuel lines
Air ducts
front motor mount bolt
Main electrical harness
Throttle cable
Misc vac lines
Alt. power cable.
A/C if equiped.
IMO....I'd rather lay in the mud.Joe Lutz
