the b3 produces its peak hp at 5200 rpm, i think, been awhile since i checked a car magazines test table, after which it falls off pretty sharply, my machine shop told me that the stock motors start to float at 6000 rpm, there is an article on fms about a festiva car and driver built back in 89, and taking it past 5800 rpm was pointless because the carb starved for fuel, especially while cornering. driving mine i never take them past about 5000 rpm, mostly because the exhaust note goes flat, and in my experience, if the tone goes flat, youre no longer making power, shift it.
Red line?
Originally posted by CharlieZ View PostLook at the HP & torque v.s. RPM charts of any engine. Once the HP curve starts dropping at a given RPM, what's the point of going deeper in to the danger zone?
BTW, does anyone have the curves for the B3?Steve GT
RED LINE...RED LINE...?
How insensitive can y'all get?
YOU KNOW ITS MY TRIGGER PHRASE !
Look at this...http://www.fordfestiva.com/forums/sh...ewpost&t=16188'88 Festiva L, stock carby engine (with exhaust upgrade), 4 speed tranny. Aspire Struts and Springs, Capri 14" wheels, interior gutted, battery in back
'92 Geo Metro XFi
'87 Suzuki Samurai
'85 F150, modded 300cid
Originally posted by Omgloltokyodrift View PostB-Series' tend to do this, once the valves float...
Been there, done that.Trees aren't kind to me...
^^^agreed
visual evidence suggests a lean condition highly concentrated in the failed cylinder, probably due to a combination of a partially clogged injector coupled with an intake air leak.Jim DeAngelis
kittens give Morbo gas!!
ok, children, can you say: "lean misfire"?
all together now...Trees aren't kind to me...
