is there a drain plug on this thing? need to change the tranny fluid and my friend tells me auto's don't have drain plugs. and does it take atf or that mercron 3 stuff?
auto tranny?
Yes there is a drain plug on these tranny's (some autos don't have drain plugs, most do)
It's a fairly large plug, located along the tranny support crossmember. Prettty sure if you lie on your stomach and look under the car you'll see it on the righthand side....1990 Festiva
- 5 spd. swap
- B6 SOHC swap
- Custom Interior
**********Currently Under MAJOR Reconstruction************
Isnt it standard practice that if youre going to drain the fluid in the tranny that you also change the filter? I thought thats why they "didnt" have a drain plug.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
not all auto trans' have a filter. Some, like the Festy, just have a screen. Most auto do not have a drain plug, because the specified fluid change interval is either significant (60k miles or so), or there is no specified change interval. The Festy/Aspire F3A trans uses plain old Mercon/Dexron III. Drain and fill uses about 3.5 quarts.Jim DeAngelis
Is it advisable to drop the pan and clean that screen out periodically?Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
YES!! esepcially if you can't tell if there's debris when using the drain plug. Pulling the pan will give you a better picture of how the trans is wearing.Trees aren't kind to me...
Well I guess I put that one the list of "To Dos". Bella has 86k on her and I bet its never been changed.
Thanks guys. And sorry I didnt mean to swipe anyones thread with my questions. But this is good info for anyone with an Auto Festy.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
