auto tranny?
  • auto tranny?
    is there a drain plug on this thing? need to change the tranny fluid and my friend tells me auto's don't have drain plugs. and does it take atf or that mercron 3 stuff?
    93-1.6l
    f.s.- fms bodykit.
    Yes there is a drain plug on these tranny's (some autos don't have drain plugs, most do)
    It's a fairly large plug, located along the tranny support crossmember. Prettty sure if you lie on your stomach and look under the car you'll see it on the righthand side....
    1990 Festiva
    - 5 spd. swap
    - B6 SOHC swap
    - Custom Interior
    **********Currently Under MAJOR Reconstruction ************
      just regular atf? the local parts guy couldn't tell me for some odd reason.
      93-1.6l
      f.s.- fms bodykit.
        Isnt it standard practice that if youre going to drain the fluid in the tranny that you also change the filter? I thought thats why they "didnt" have a drain plug.
        - Unknown
        - Quentin Crisp
        - Bumper Sticker
          not all auto trans' have a filter. Some, like the Festy, just have a screen. Most auto do not have a drain plug, because the specified fluid change interval is either significant (60k miles or so), or there is no specified change interval. The Festy/Aspire F3A trans uses plain old Mercon/Dexron III. Drain and fill uses about 3.5 quarts.
          Jim DeAngelis
          kittens give Morbo gas!!
            Is it advisable to drop the pan and clean that screen out periodically?
            - Unknown
            - Quentin Crisp
            - Bumper Sticker
              YES!! esepcially if you can't tell if there's debris when using the drain plug. Pulling the pan will give you a better picture of how the trans is wearing.
                ^^^ agreed
                Jim DeAngelis
                  Well I guess I put that one the list of "To Dos". Bella has 86k on her and I bet its never been changed.
                  Thanks guys. And sorry I didnt mean to swipe anyones thread with my questions. But this is good info for anyone with an Auto Festy.
                  - Unknown
                  - Quentin Crisp
                  - Bumper Sticker
