Has any one ever modified the doors or anything to make heat come out of the dash vents ? Can it be done ?
Heat from dash vents
Defrost forces all the heat out of the window vents (top of dash) which pretty much heats the upper area. You feel the heat on your face which fools you into believing you are warm.
Has anybody tryed modifing an air box from a AC car?Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
95 Taurus SHO auto 265hp
94 F150 351W auto (for sale)
95 Honda 1500 Goldwing SE
95 Iszuzu Trooper LS
it's the same plenum. AC just adds an evaporator to the inlet side of the plenum, right behind the glove box.Originally posted by elcamino1 View PostHas anybody tryed modifing an air box from a AC car?Jim DeAngelis
Thanks Jim,I just assumed that if you got cool air you may be able to get hot!Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
solenoid valve in the coolant line...Originally posted by FB71 View Postyou'd never be able to shut off the heat!!! You'd have full heat all the time!
Another plus would be that (I assume, never seen an evap case) there would be room for a much bigger heater core.89SX funtop! Fully loaded!
RIP 90LX
gate valves don't stop all heat transfer. Ask owners of Lincoln Aviators...Originally posted by stefan View Postsolenoid valve in the coolant line...
the evap cases are fairly small. Evap is about the same size as the heater core.Jim DeAngelis
Why? Is it just because of cheep factory valves not completely stopping coolant flow?Originally posted by FB71 View Postgate valves don't stop all heat transfer. Ask owners of Lincoln Aviators...
It would be better than nothing... and it would mean... DASH HEAT!!!!
It would be worth the effort up here.89SX funtop! Fully loaded!
RIP 90LX
coolant on either side of the valve, in very close proximity. Heat still transfers.Originally posted by stefan View PostWhy? Is it just because of cheep factory valves not completely stopping coolant flow?
It might be beneficial in the Great White North! I don't really miss dash heat down here in Merry-land...Jim DeAngelis
