Anyone got a pixs of an evap case? we never got a/c up here
Heat from dash vents
Why couldn't you mount one of those ceramic heaters that are supposed to be so efficient and mount it in the car with a power inverter. You would have instant heat. with a little duct work, its own circuit, with a power switch it could be turned off and on as needed. - Wow - that was a good idea maybe i will try it myself.ROBc
Your average 120v household heater is 1500w...Originally posted by rcottle View PostWhy couldn't you mount one of those ceramic heaters that are supposed to be so efficient and mount it in the car with a power inverter. You would have instant heat. with a little duct work, its own circuit, with a power switch it could be turned off and on as needed. - Wow - that was a good idea maybe i will try it myself.
1500w/12v = 125A... the festys alt is what... 55A?.. In otherwords.. the factory alternator doesn't make nearly enough power to run a heater.89SX funtop! Fully loaded!
RIP 90LX
Here is what I would call the bottom line. A festiva with the right thermosat will roast you out. It never bothered me that it doesn't blow out of the dash. we are so close to the windshield in a tiny festiva that it really doesn't matter.youtube.com/neanderpaul 88 festiva LX w/BP G25 MR 5 speed waiting for wiring- 93 Festiva GL auto w/ air, waiting for B6t/G4A-HL - 98 Nissan Quest - 02 Mazda protege 5 wife's DD
Up here it is a whole different story. It is -20°F to -40°F around here this time of the year... My car certainly makes quick heat... but the door seals exct let the heat out just as quickly as the heater pumps it out.89SX funtop! Fully loaded!
RIP 90LX
Can't you replace the door seals?
If they are not ripped or torn roll down your windows and from the inside of the door bend your window frames in a little and see if that helps them seal a little better,it worked for me!Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
95 Taurus SHO auto 265hp
94 F150 351W auto (for sale)
95 Honda 1500 Goldwing SE
95 Iszuzu Trooper LS
^^I have done that too...works great."FLTG4LIFE" @FINALLEVEL , "PBH"
My door seals aren't ripped up or anything, and I've done the window frame bend trick. Yet they still whistle air abit.Originally posted by elcamino1 View PostCan't you replace the door seals?
If they are not ripped or torn roll down your windows and from the inside of the door bend your window frames in a little and see if that helps them seal a little better,it worked for me!89SX funtop! Fully loaded!
RIP 90LX
then bend ot a little more...but be careful....lol"FLTG4LIFE" @FINALLEVEL , "PBH"
