Wiper arm removal
    I've used a battery terminal puller before for stuff like that,just make sure you leave the nut on(loose of course) so you dont damage the threads.
    96 Ford F-150 XLT
    93 Festiva L (Modified)
    92 Festiva L
    68 Mustang GT 428cj
      Originally posted by WmWatt View Post
      Raise the wiper arm to vertical. Lay a putty knife or similar under the base to protect the car finish. Wiggle and pry up all around with a big screwdriver.
      I tried that. Thanks.
        I'm gonna' try this as a last resort. That's probably the best thing to do not to break anything.
          If you have a spare arm,just cut it off the stud and be done with it!!! :grin:
          If you don't have one,I'm sure someone here will help you out!!
          99 Dodge Caravan SE
          95 Taurus SHO auto 265hp
          94 F150 351W auto (for sale)
          95 Honda 1500 Goldwing SE
          95 Iszuzu Trooper LS
            I have used channel locks to kinda squeeze up the arm. Place one edge under the wiper arm and the other on top of the stud and squeeze.
            93 GL modyfied!!!
            :fish:
              Now why didn't I think of that?
              I'd say by the responses here, this must be a common problem.
                ^^ noy really. I just take mine and wiggle them off, gotta get abusive with older cars!
                  It is a common problem. Yours sounds uncommon though. You still ain't got it off? OK, I see the good advice you got is good: take hold of arm and pull/wiggle/move up&down&side2side. If for some reason that don't work(make sure nut is off or up aways), then I got a suggestion. Wrap a poly rope around the "base" of the arm then attach it to a cherry picker.....follow me?
                  • #24
                    ^^lol.....yeee hawwwww
                    • #25
                      I don't like the wiggle and pull on the arm method because there has been some issues with the inner cowl ripping where the arm is attached to the car. This is diffecult to fix when the inner panel tears.
                      93 GL modyfied!!!
                      :fish:
                      • #26
                        like what happened to my green festiva, but i don't know what caused it to "rip" i think it just rotted away
                        • #27
                          That is the primary specific reason I didn't want to get rough with it.
                          I'm not in a hurry. I'll try to channel lock deal tommorrow. Then I had a thought of just leaving the nut loose and running the wipers in the rain and see if that would pop them loose.
                          • #28
                            Was at Autozone today for a valve cover gasket and saw the battery terminal puller $5.
                            Think it might do the job and cheap,
