I am in the process of changing my front wheel bearings and I cannot figure out how to remove the rotor and hub from the steering knuckle. There are 4 bolts that holds the rotor and hub onto the steering knuckle but you cannot fit a socket on the head because half of the bolt head is hidden under the steering knuckle.
I work in a fabrication and machine shop and the head machinest told me that he could possibly fabricate a new spacer that goes in between the bearings or machine down the original in case it has to be done.
I was trying to get a head start on dissassembling this component so my machinest can press the old bearings out and press the new ones in.
Any help would be greatly appreciated.
Don't the pins only go on one way? You are talking about the two pins that hold the pads onto the caliper, right? Thanks again.
