Ok.. I finally got the pulley off and all that good stuff,but I pulled the timing gear off the crankshaft... so how do I find TDC at the compression stroke so I can get the timing right again... I found TDC but I dont know if its the compression stroke
Crank pulley
Theres a mark on the timing gear and block to line up on.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
yep.Originally posted by zoe60 View PostIt goes on the metal tube that goes around the front of the engine, where the two pipes slide together. You'll find it if you take them apart.
-Aspire brake swap COMPLETE!
i look at it like hey, i already got the o-ring, might as well do it while i am here and have it all apart.
