I have a 91 Festiva and the E Brake will not stop the car from rolling backwards down the drive. I will hold the car from moving forward if you give the car some gas. Where should I start on fixing this problem so I can pass state inspection?
E brake will not hold the car
likely what you're problem is that the little lever that the e-brake pulls on your rear drum (hard to describe without looking at it) is rusted and doesn't move... therefore doesn't engage when the e-brake is pulled.
have someone pull the e-brake while you look at one of the wheels. this lever moves toward the center of the vehicle when engaged...
my car had this last summer, and what you need to do is take the drum off and get some PB blaster and get that lever to move freely again.... now, i always put my e-brake on when i park to keep those levers moving and not setting...
hope this makes sense.
-Aspire brake swap COMPLETE!
I haven't had the drums of mine yet, was wondering if they have an auto adjuster (like newer Focus') for the shoes or if it's the adjustable clicker type. If they are adjustable maybe you could have gotten away by turning them out a few clicks?02 Super Duty XLT 4x4 7.3 $12,000.00 (still paying on)
00 Grand Am GT 3.4 $6,000.00 (still paying on)
89 Festiva L 1.3 $225.00 (paid off 1st day!)
glad you got it fixed.Originally posted by ihawk33 View PostThe shoes were badly worn. I replaced the shoes and now it works. I only have had the car about 2 months and finally replaced the rack and pinion now this so I am now ready to register and get the car inspected.
yes, there is a spring adjustable clicker mechanism that as the drum shoes wear, it ratchets accordingly. its not "auto".Originally posted by mrgrimm View PostI haven't had the drums of mine yet, was wondering if they have an auto adjuster (like newer Focus') for the shoes or if it's the adjustable clicker type. If they are adjustable maybe you could have gotten away by turning them out a few clicks?
At least, that's what it does until the springs lose too much of their tension.Originally posted by ejp2fast View Postglad you got it fixed.
1989 L - 247K miles Slick
I do not recall seeing an adjuster. I have had my back brakes apart on a couple cars and I only recall the wheel cylinder and springs....hmmmmmm.Originally posted by ejp2fast View Postyes, there is a spring adjustable clicker mechanism that as the drum shoes wear, it ratchets accordingly. its not "auto".
^^ According to my Hayne's, and my car, there are self adjusters in the rear brakes. Towards the top, kind of just below the cylinder. If I can figure out where I put the old ones I just took out, I'll take a pic. The brake hardware kit I used came with new ones.
Yours came with new adjusters? The ones I've used from FMS only have springs, not the ratcheted adjusters themselves. What kit is this & where do you get it?Originally posted by batstiva View Post^^ According to my Hayne's, and my car, there are self adjusters in the rear brakes. Towards the top, kind of just below the cylinder. If I can figure out where I put the old ones I just took out, I'll take a pic. The brake hardware kit I used came with new ones.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
