seems my rubber seal is off in my driver door... anyone got some pics of the whole window system?
drivers side window off track?
Pic of your problem might help us help you!'93 Blue 5spd 230K(down for clutch and overall maintanence)
Is it torn? If not you might be able to just work it back in, maybe with a flat screwdriver.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Is the rubber piece separating from the door, or is the window not lining up with the rubber piece? Just clips that hold the bottom pieces on, not 100 percent sure on the rest of the way around the window.
1989 L - 247K miles Slick
i believe the clip that holds it (rubber seal) down IN the door is out and rattleing around in my door which would explain my rattle.Originally posted by batstiva View PostIs the rubber piece separating from the door, or is the window not lining up with the rubber piece? Just clips that hold the bottom pieces on, not 100 percent sure on the rest of the way around the window.
Roll the window down half-way. Take off the door panel, and loosen the two 10mm bolts that hold the window on. Re-positon the window in the track. If it falls out agian you will probably need a new window felt or regulator.---------------------------------------------------
