my grandfathers 93 has developed a tapping sound that speeds up as you accelerate. im thinking its something to do with the valves , the car seems to be running fine , just with a tapping. any ideas guys ? thanks
tapping sound coming from head
Sounds like an HLA is stuck/collapsedHave owned 9 so far
hla ? not sure the grade of oil , he had it changed at texaco , but he said it was tapping before. weve got 2 spare motors so ive got plenty of spare parts if need be.Originally posted by m715 View PostSounds like an HLA is stuck/collapsed05 focus zx3 5spd 180k 2.5 inch mbrp exhaust , steeda sri and ford racing dynamic suspension
actually, hydraulic lash adjuster, festys don't have lifters, just rockers.Originally posted by perucho View Posthydraulic lifterTrees aren't kind to me...
Originally posted by FestYboy View Postactually, hydraulic lash adjuster, festys don't have lifters, just rockers.
then what are these????
i believe they have it wrong---only 1990 and up use them and/or fuel injected modelsLast edited by mechanicaldj; 10-21-2009, 11:11 PM.
I am the original
isnt 15w-40 a little to thick for these engines? mine has the same tapping sound but i was just going to use 10w-30 but if 15w-40 it ok to use and it helps the tapping noise im going to change weight....(90 festiva lx STOCK)
(Transmission is going)
(b6 swap maybe)
(Working on interior-Navy Blue paint on the dash)
MY OTHER CAR......
1986 cutlass supreme
Engine: Rebuilt SS 305 crane cam,weiand,3 angle valve job/port and polish,.030 over..
Trans: Rebuilt Th-350 trans-go shift kit
Rear axle: Monte ss 10 bolt 3.73 Limited slip
In the Subaru world this is known as the TOD (tick of death). But not to worry too much. Try cleaning out the motor with Sea Foam. Add it to the oil, idle it for ten minutes or so, drain the oil and change oil/filter.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
