tapping sound coming from head
  • tapping sound coming from head
    my grandfathers 93 has developed a tapping sound that speeds up as you accelerate. im thinking its something to do with the valves , the car seems to be running fine , just with a tapping. any ideas guys ? thanks
    05 focus zx3 5spd 180k 2.5 inch mbrp exhaust , steeda sri and ford racing dynamic suspension
    Sounds like an HLA is stuck/collapsed
    Have owned 9 so far
      What grade engine oil are you using? Mine was doing the same and 15w-40 took care of it. However, it doesn't get that cold here.
      Oscar
        hla ? not sure the grade of oil , he had it changed at texaco , but he said it was tapping before. weve got 2 spare motors so ive got plenty of spare parts if need be.
          hydraulic lifter
          Oscar
            Originally posted by perucho View Post
            hydraulic lifter
            actually, hydraulic lash adjuster, festys don't have lifters, just rockers.
              then what are these????
              Get the best deals for Festiva Lifter at eBay.com. We have a great online selection at the lowest prices with Fast & Free shipping on many items!
              i believe they have it wrong---only 1990 and up use them and/or fuel injected models
              I am the original
                hehee yes, thanks
                Oscar
                  isnt 15w-40 a little to thick for these engines? mine has the same tapping sound but i was just going to use 10w-30 but if 15w-40 it ok to use and it helps the tapping noise im going to change weight....
                  (90 festiva lx STOCK)
                  (Transmission is going)
                  (b6 swap maybe)
                  (Working on interior-Navy Blue paint on the dash)
                  MY OTHER CAR......
                  1986 cutlass supreme
                  Engine: Rebuilt SS 305 crane cam,weiand,3 angle valve job/port and polish,.030 over..
                  Trans: Rebuilt Th-350 trans-go shift kit
                  Rear axle: Monte ss 10 bolt 3.73 Limited slip
                    In the Subaru world this is known as the TOD (tick of death). But not to worry too much. Try cleaning out the motor with Sea Foam. Add it to the oil, idle it for ten minutes or so, drain the oil and change oil/filter.
