i'm only 20 min away..... i can help, really.
The darn thing wont start...
The motor will REV up... they are vacuum lines, no pressure to bubble.Originally posted by ShagFestiva View Postyeah I plan on getting those fuses because the old one is just going to give me headaches down the road. Thanks shorty ill try the WD40 trick. Im guessing it bubbles up if theres a lvacuum eak? and the coolant leak isnt that bad dont worry the motor wont burn up, its just a small drip and i dont drive the car yet. Only test drives every once in a while.
Well the idling problem is fixed. I put in those fuses and checked out the air filter. When i pulled the top of the box off and got the filter out, there were parking tickets shoved in the bottom of the box under the filter LOL. Anyway, I then messed with the idle screw a little bit and she runs and idles like a champ.Tyler
91 Festiva, 5spd, B8 swapped, now for paint and suspension
WTH? WHY would anyone do that?!?!?!Originally posted by ShagFestiva View PostWhen i pulled the top of the box off and got the filter out, there were parking tickets shoved in the bottom of the box under the filter LOL.
