Help!!
  • Help!!
    I am doing the rear brakes on my festiva and was not thinking and did not look where the self adjuster spring hooked on when i took it off. could anyone tell me where this spring goes? thanx
    A nice car is like another mans woman, you can look but do not touch!
    91 civic h/b built and boosted a6/z6 and wagovan real time 4wd conversion
    68 plymouth barracuda fast back 4spd (summer car)
    91 L (RIP)
    65 plymouth sport fury 2dr convertible 440 (SOLD)
    63 plymouth valiant 2 dr sedan (SOLD)
    93 dodge dakota 5.2L 4x4 (SOLD)
    86 Ranger 2.9L 4x4 with 4inch lift (SOLD)
    AND I WISH I STILL HAD THEM ALL!
    So no manual for reference?
    What about the other unmolested side?
    Use the Search option above and look for brake pics, I'll do the same.
    If I find it I'll post it here.
    Maybe the Mod of this forum will take pity and provide a pic.
    It's not difficult it can't go but so many places.
    A pic would make it easy, describing it is more difficult.
      Pictures are kind of crappy, my camera does not do up close real well. :roll:
      But I hope this helps.
      1988 L - 232K miles Batstiva
      1989 L - 247K miles Slick
        Thanks Batstiva, I was having no luck via search for a pic.
          Batstiva - is that a pic you took? in black and white?
            It's a picture of a rather small black and white pic in my Haynes.
              they don't have color cameras in West Virginia..............j/k
                Ah makes sense batman :lol: had me wandering for a minute there :lol:
                  thanks guys. it turns out for some reason the hardware kit i have comes with an e brake return spring and a self adjuster spring such as in the picture on festivamotorsport.com under the owners recources and festiva part diagrams. but i looked on all data and it showed only the e brake return spring and no self adjuster spring so i put it together as on all data and it seems to work fine. strange considering there was two spring on there before
                  91 L (RIP)
                    also looks like there's only one spring on the diagram from the haynes manual above
                    91 L (RIP)
                      there should be a spring on the bottom side of the adjuster to the plate where the ratcheting part is - I'm looking for a pic
                      Ok everything highlighted is part of the hardware kit you should have gotten.
                      Yellow - Hold downs consisting of a spring or spring metal and a pin (if your kit has a spring you will also have a spring keeper to hold the spring on the pin)
                      Blue - these are the springs that keep you shoes withdrawn
                      Green - this is what returns the parking brake after you remove the tension
                      Red - I'm thinking this is the spring your missing it is what keeps your shoes in proper adjustment
                      92 GL - parts car
                      97 aspire - parts car
                      87 323 DX - daily driver
                        yes that's the one but where does it hook on cause i can't seem to find anywhere it might go. and in batstiva's picture and the diagram i sourced on all data it only showed the spring that is represented by green in your picture. it also seems like the adjuster works fine without this mystery spring on it so i'm not to sure what the deal is.
                        91 L (RIP)
                          Okay, it looks like that red spring connects on both ends to the self adjuster, and is tensioned when the rear brake shoe is locked in place by the pin and hold down clip, but I'd have to go out and pull a wheel to verify exactly where behind the rear shoe, on the self adjuster, it actually connects. Anyone with a rear wheel/brake pulled already that can verify this?
                            All mine have been previously disassembled for the spindels.
                            But seriously, Bazzy16, did you pull appart both sides when you started this?
                              yes both sides were pulled apart. and i put it all back together minus the red spring and just tried pushing the shoe out to see what the adjuster would do and it worked fine. it swung out and then when the shoe returned it locked it self adjusted out. the diagram on all data has the top blue spring in festiva tunner's diagram labeled as the adjuster return spring aswell as the spring that keeps tension on the shoes. also festiva tunner's diagram is the one i was initially using for refference and every other diagram i've found does not have the red spring in it. so i think i'll just try and run it how it is because everything seems to work and i've looked several times and cannot find any logical place that the spring would attach.
                              91 L (RIP)
