If it isn't broke...........
Strange Wire on the Carb
Have owned 9 so far
34mpg averageOriginally posted by m715 View PostIf it isn't broke...........
it's pretty broke. I can drive my Bimmer for that, and have a lot more fun.
Would hot intake hurt? I noticed my flap that pulls air off the exhaust manifold shield stays at full open. I'd think that'd actually HELP, from what i've seen on ecomodder and such.
looks like a fuel cut solenoid to me. 34 mpg ain't broke, things just need TLC and adjustment.Trees aren't kind to me...
I was getting 38-40 when i got it 4 months ago.......I dunno where to start checking and adjusting. I figured a carb swap and removal of all that vacuum stuff would eliminate at least 2 dozen points of failure.
I'm 100% open to suggestions.....although I've got about $100 invested in the swap.
it's been given a proper tune-up and PROPER adjustment of timing? you can see that kind of milage drop if the timing is out by as much as 2*.
just a thought...Trees aren't kind to me...
Umm, likely no on both accounts. Valves are adjusted to spec (according to haynes) toward the loose side. if these are like bimmers at all, tickity is better than torched. The plugs are also <2 months....now that I think, i didn't change the gaps, but they were all ±.003", amazing on it's own.Originally posted by FestYboy View Postit's been given a proper tune-up and PROPER adjustment of timing? you can see that kind of milage drop if the timing is out by as much as 2*.
just a thought...
What do I need to do, or what haynes page?
Having idle troubles too. races to 3k sometimes, rarely under 1200, but it'll randomly just go dead when idling, often when I clutch to slow down for a turn, poof, dead. I usually just clutch it in 3rd and bump off.Last edited by odiekokee; 12-19-2009, 11:03 PM.
well check the plugs (i had new plugs that failed in 3 mos). the inconsistant idle is prolly a linkage issue (lack of lube). also while you're in there, pull the wires, cap, and rotor and inspect for wear.Trees aren't kind to me...
Ok, linkage where? or should I just give a good lubricating to every moving thing around the carb including cables? The plugs, I'll check, but the old ones looked good, no abnormalities based on the normal visual charts. Wires looked ok, and best i could tell, the cap/rotor looks to have been replaced sometime not long before I got the car.Originally posted by FestYboy View Postwell check the plugs (i had new plugs that failed in 3 mos). the inconsistant idle is prolly a linkage issue (lack of lube). also while you're in there, pull the wires, cap, and rotor and inspect for wear.
What about the timing?? how deep a job is that?
Should i surrender on the carb swap?
timing is easy if you have a light (beg, borrow or steal on if you have to). a general spray down of the carb isn't a bad idea, but i'm refering spicificaly to the linkage next to and behind the cable cam (choke linkage).Trees aren't kind to me...
I've gotta avoid silicone oil based lube, right?? I love the stuff, but I know most of the times it'll eat an o2 sensor, anything else to be aware of?Originally posted by FestYboy View Posttiming is easy if you have a light (beg, borrow or steal on if you have to). a general spray down of the carb isn't a bad idea, but i'm refering spicificaly to the linkage next to and behind the cable cam (choke linkage).
