Originally posted by hot4dl8ly
Question about key(s)?
the easiest way is to slot them for a flat blade screwdriver and turn them out - a dremel does the trick nicely took all of 15 min to swap out the entire lock set and ignition
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
^^That's how I've done them in the past. I used either the dremel or an air die grinder. Either works well
There's no lock assembly left in the cylinder. The previous owner drilled it out and I have to crank it with a shorty screwdriver. It's Ghetto Fabulous!!!Originally posted by Hot_Wheels View Postfind some people with festiva keys, i know my key works on other peoples festiva and theres works on mine. i had a set from my old 88 and it worked too
I used an old toyota key to unlock mine. Don't ask me how many times I've locked my keys in my car. LoL-Greg
Redneck Engineer
FOTY - '09
^^Now THAT IS FUNNY
I have a big ring of Ford keys for doors and ignition that I used in the junk yard. It usually doesn't take long to find one. I think most people would be worried if they knew just how fast you can find one LOL. I only keep the Ford keys because that's what I personally tinker with. All others are scrapped. Well, except for the imports now that I know some parts interchange
My 1983 toyota celica key will open ALOT of imports.
And I miss that car.
And just for no reason I want to say if i ever put all my cars that I've owned in my sig. It'd be HUGE.Last edited by eurotiva; 01-05-2010, 09:16 PM.-Greg
Redneck Engineer
FOTY - '09
I thought about trying a Toyota cylinder. I have an old Tercel on the yard that still has the key and the ignition cylinder looks ALOT like the Festiva, but I couldn't get the key out of the ignition. For some reason it is really stuck. Still turns but WOULD NOT come out. :cussing:
^ do you need a lock cylinder and key?-Greg
Redneck Engineer
FOTY - '09
did you think of pulling the passenger cyl and giving it to a locksmith to make you a new key? the code for the car is on the cyl...Trees aren't kind to me...
Alot will do that. The keys from my 88 will unlock my 93 and vice versa. Havent witnessed it yet myself but have read of being able to start some cars as well.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
apparently Scrappy's key started 9 cars at Madness... who knew!?Trees aren't kind to me...
My car didn't come with keys, either.
I replaced the ignition lock with one from an MX-6 in a junkyard.
I want to lock my doors now.
I want to go the locksmith route so I can also lock the hatch.
How do I remove the passenger lock cylinder? Last time I had the door panel off I looked at it, but couldn't really see it or figure out how to remove it.~Austin
Red 88 L (Ocho)
