Question about key(s)?
    Originally posted by hot4dl8ly View Post
    You can also use center punch to "walk" those headless bolts out of ign cylinder to column, still a PITA.
    the easiest way is to slot them for a flat blade screwdriver and turn them out - a dremel does the trick nicely took all of 15 min to swap out the entire lock set and ignition
    92 GL - parts car
    97 aspire - parts car
    87 323 DX - daily driver
      ^^That's how I've done them in the past. I used either the dremel or an air die grinder. Either works well
      Originally posted by Hot_Wheels View Post
      find some people with festiva keys, i know my key works on other peoples festiva and theres works on mine. i had a set from my old 88 and it worked too
      There's no lock assembly left in the cylinder. The previous owner drilled it out and I have to crank it with a shorty screwdriver. It's Ghetto Fabulous!!!
      WWZD
      Zulu Ministries
        I used an old toyota key to unlock mine. Don't ask me how many times I've locked my keys in my car. LoL
        -Greg
        Redneck Engineer
        FOTY - '09
          ^^Now THAT IS FUNNY
          I have a big ring of Ford keys for doors and ignition that I used in the junk yard. It usually doesn't take long to find one. I think most people would be worried if they knew just how fast you can find one LOL. I only keep the Ford keys because that's what I personally tinker with. All others are scrapped. Well, except for the imports now that I know some parts interchange
          WWZD
          Zulu Ministries
            My 1983 toyota celica key will open ALOT of imports.
            And I miss that car.
            And just for no reason I want to say if i ever put all my cars that I've owned in my sig. It'd be HUGE.
            -Greg
            Redneck Engineer
            FOTY - '09
              I thought about trying a Toyota cylinder. I have an old Tercel on the yard that still has the key and the ignition cylinder looks ALOT like the Festiva, but I couldn't get the key out of the ignition. For some reason it is really stuck. Still turns but WOULD NOT come out. :cussing:
              WWZD
              Zulu Ministries
                ^ do you need a lock cylinder and key?
                -Greg
                Redneck Engineer
                FOTY - '09
                  I purchased one from TONYCASH on Monday. But thank you for the offer
                  I did however pm you about some tail lights you mentioned in another thread
                  WWZD
                  Zulu Ministries
                  • #24
                    did you think of pulling the passenger cyl and giving it to a locksmith to make you a new key? the code for the car is on the cyl...
                    • #25
                      ^^ Yup, that's how I got the new door keys
                      Another funny thing: The key that's in the ignition cylinder I got from TONYCASH will unlock my doors too if I wiggle it just the right way...LOL
                      WWZD
                      Zulu Ministries
                      • #26
                        Alot will do that. The keys from my 88 will unlock my 93 and vice versa. Havent witnessed it yet myself but have read of being able to start some cars as well.
                        - Unknown
                        - Quentin Crisp
                        - Bumper Sticker
                        • #27
                          apparently Scrappy's key started 9 cars at Madness... who knew!?
                          • #28
                            My car didn't come with keys, either.
                            I replaced the ignition lock with one from an MX-6 in a junkyard.
                            I want to lock my doors now.
                            I want to go the locksmith route so I can also lock the hatch.
                            How do I remove the passenger lock cylinder? Last time I had the door panel off I looked at it, but couldn't really see it or figure out how to remove it.
                            ~Austin
                            Red 88 L (Ocho)
                            • #29
                              There's a metal spring lock that holds it in place. You just slide it out from under the lock assembly. It has a raised tab on one side to push against with a screwdriver.
                              WWZD
                              Zulu Ministries
                              • #30
                                Alright.
                                Another time tiny Asian hands would be useful...
                                ~Austin
                                Red 88 L (Ocho)
