With a metal one put some sort of sealer around it, the part store can give you the right type. Just make sure you can drive it in straught and all the way. The rubber ones are a breeze to install, just push in hole and tighten down. Take your old one with you to make sure you get the right size.
Hulkstiva is sick!!
Awesome. Thanks! Stupid me screwing things up by not putting anti-freeze in the car!"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
Does anyone know the correct size of the freeze plug for our cars? I gotta send my mom to pick it up for me since I'm at work. Looking on the autozone website they list 2 different sizes for the metal ones....30mm and 35mm, but the rubber ones are only 35mm"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
Thanks goodness for freeze plugs !! Now go buy some antifreeze.sigpic
Originally posted by freshtiva View PostThanks goodness for freeze plugs !! Now go buy some antifreeze."Lane, I've been going to this high school for seven and a half years. I'm no dummy."
Since all the "anti-freeze" :banghead: is obviously frozen in my car, what's the best way I should go about getting it thawed and drained out of the car? The weather is gonna continue to be pretty cold around here, but I gotta get this car running somehow! I don't wanna make matters worse by starting the car up again. Btw, before I left for work today I pulled the drain plug and disconnected one of the radiator hoses in hopes that some of it would thaw out, but I'm sure what's left in there will be frozen again by the time I get off workLast edited by lanemeyer14; 01-04-2010, 05:08 PM."Lane, I've been going to this high school for seven and a half years. I'm no dummy."
Did some searching....came up with a few options for heating it up. Park it in a heated garage, block heater, engine blanket, pouring hot water on the engine. Not really sure what to do"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
Originally posted by 25Horseplay View PostPut a small heater next to the engine to thaw it out. Or you can start it for a short period to put some heat in it, as long as you don't overheat it you won't do any damage."Lane, I've been going to this high school for seven and a half years. I'm no dummy."
Hulk is pissed at you...................................-Greg
Redneck Engineer
FOTY - '09
.... I don't think you're going to like him when he's angry.-Caleb
Originally posted by cracked.com on the M203 w/ M433 HEDPSo, for about the same price as a fully-loaded 1993 Ford Festiva, you could also wield the power to obliterate a small village in the blink of an eye.
Got the hulkster to my mom's house after work tonight and went straight to work on it. Put the new freeze plug in then poured some water in the rad. to check for leaks. Sure enough the water pump was pouring water! Tore everything apart and got the water pump out and it had a HUGE crack down the side of it.....thanks a lot frozen "anti-freeze" aka "water". So I learned my lesson, and will not forget to put anti-freeze in the car this time!"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
Which style freeze plug did you use?-Greg
Redneck Engineer
FOTY - '09
