Blinkers dont flash
    Originally posted by skinnypin View Post
    Thank you. Thats what i thought but wanted to make sure before i tore into the dash.
    You dont need to tear up the dash to get at that module. Its within reach from underneath.
    - Unknown
    - Quentin Crisp
    - Bumper Sticker
      Originally posted by batstiva View Post
      A bit off topic, don't you think??
      if it is the flasher module and i get to it. does anyone know how much it is to replace?
      Just checked Advance Auto's website. Somewhere between 10 and 12 bucks.
      Haha, the OP also threw a wheel bearing question in there a few posts back
        ^^ Yeah, just went back and noticed that. :roll:
        As to the OPs question about not having the spacer in place being a problem, the answer is yes, it will be a problem. The lifespan of your bearings will be greatly reduced, because they will not stay where they are supposed to stay. If that makes sense.
        1988 L - 232K miles Batstiva
        1989 L - 247K miles Slick
          Ok. I called who helped me do the wheel bearing because he ended up doing most of the work. I myself dont remember putting that back in there.
            Any more detail on where it is? Where is it located if I can get to it from underneath. Could you possibly post a picture where it is at. My friend from Napa priced out a new flasher for me already for $12.00. Getting it tomorrow.
              Originally posted by MONSOON View Post
              There is a Flasher Module located behind the Fuse Panel under the dash. It is not uncommon for them to go bad.
              Once you pick the part up and know what it looks like, I'm sure you'll be able to locate it where MONSOON has described
                I will try to see if that works. Dont know if we got the right part ordered in.
                  Found the Flasher. The one I ordered in turned out to be the wrong one but I replugged in the oridinal one and it started working again. Bad connection i guess. Got the right one being ordered in as a back up. Thanks for the help.
                  • #24
                    xxx
                    • #25
                      • #26
                        xxx - means I can't see how to delete message. all I can do is erase content. requires at least one character to post.
