1 worn or improperly adjusted linkage
2 tranaxle loose on engine
3 shift linkage not work freely,binds
4 input gear bearing retainer broken or loose
5 foreign material between clutch cover and engine housing
6 worn shift fork
7 damaged or worn constant mesh gears
8 damaged or worn synchronizers
9 damaged fourth speed gear or output gear
10 worn or damaged idler gear or bushing
11 low trans fluid.
6 worn shift fork
11 low trans fluid.
