Rear Spindle / Bearings Failed (Again)
    Help!! The left rear side wheel bearing is stuck on the spindle.What can I do?
      If you have to order a spindle anywho, try and get a 91-93 they have the castle nut and cotter pin.
      (paperboy 23) 88 Festy Blue, aspire Engine/trans/efi swap,
        carefuly cut it off.... take the drum off (done) and then remove as much of the bearing cage as you can so all you have is the inner race left. then take a cutoff wheel and carefuly cut into the race (typicaly at about 60* to perpendicular for wheel clearance). what you're trying to do is not cut all the way through, but cut a channel into the race nearly through and then take a chisle and hammer it into the channel you just cut, this will crack the race and give you the clearance you need to remove the race without damaging the spindle.
          FYI...I have an 88 and it has cotter pins and castle nuts on the spindles.
          Dan
            Dang might have to grab those the next time I see one in the junkyard! Today I replaced the bearing on the drivers side.. lets just say I think it was loose. Had a shimmy at high speeds that I could figure it out apparently that was it as it's gone. That tire probably would of passed me on the way to St. Louis!
            91 rusty Festiva 260k
