Originally posted by codex
Fix this and your capabilities are expanded.
Do you have a reciprocating saw or have access to one?
Correct, Do Not drive it.
Do you have another vehicle for transportation?
We will get the correct nut parameters, M1?x1.??.
Anyone know the correct specs for this nut.
Otherwise, hit Lowe's Metric department and check the thread of the bolt that came with your kit.
Then find the corresponding nut, better if its a flare nut (back end of the nut wider than the front).
If not a washer with the proper dimensions to fit into the boxed area from which you will extract the remains of the broken caged nut will due fine.
i'd really like to be able to help
