Yep, you'll notice that that's where it's most exposed to road salt, etc. Plus, the junction between hard line and hose often is corroded. You may have to replace the hose as well if you can't separate the two properly.
Again, check all hard line areas for corrosion.
Are you planning any engine/transaxle removal anytime soon? That would be a good time to replace all hard lines because they'll be easier to get to.
Karl
Karl
