^^ can i delete it completley?
super super high idle wont idle down?
ummm no, you're cold start will be horrible and it may not want to start under 40*fTrees aren't kind to me...
like i said, search for vac leaks firstTrees aren't kind to me...
i hope you ment brake clean, and not brake fluid as the latter would just be bad.
you might want to also trace all vac lines to their destination and vac test them as well, as any leak can cause high idle. AND also spray around the booster on both sides of the fire wall, a bad seal there can cause a HUGE vac leak.Last edited by FestYboy; 09-12-2010, 09:47 PM.Trees aren't kind to me...
GAHHHHHHH IT WORKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!
BEST FEELING EVER FINALLY GOT I TO WORK WITHOUT ANY ISSUES!!!!!!!!!!!
HLA's were out to lunch... somehow causing the valves to float and be sticky which caused the high idle and tick
removed the HLA"S from my old car, works perfectly now, and pulls like a mother trucker vids up next in my garage bulid thread
thanks everyone for the help, it was just a matter of fixing one thing that fixed everything
