I've got a 91 ford festiva with a problem and after several tests learned its an anti theft system that I didn't know was in the car and I dont know were it is or how to fix the problem. Any help is much appreciated. Thanks lots.
Repair help
and what is your location? you can add it to your profile by going to the User CP. this can help us help you by knowing which members are close to you so that we as a whole know more about the problem we're helping you fixAndrew Walker
Current Daily Driver:
89 Nissan D21 SE V6 5 speed 4x4
Projects in the works:
84 Mercedes Benz 300D(T)(Baby) currently awaiting transmission transplant/ full on restoration
From rapid city south Dakota the problem is that it runs great and then it spits and sputters sometimes dies first thing I did was changed spark plugs wires power unit fuel filter new fuel lines battery and we checked the fuel pump fuel tank and everything else non electrical for the fuel system part i also had the idle speed adjusted and no results. The problem is that it jumps some times but not all time I take it in to a mechanic and it does nothing wrong. Did that test for codes on the check engine light and came up with code 2 and found a book that labeled it as crankshaft position sensor or idm (identity theft management) witch as far as I know is an anti theft system right?
Hey Jacob, I'm in Rapid!!! 484-2500 Westside. After 3pm most days.Originally posted by Jacob View PostFrom rapid city south Dakota the problem is that it runs great and then it spits and sputters sometimes dies first thing I did was changed spark plugs wires power unit fuel filter new fuel lines battery and we checked the fuel pump fuel tank and everything else non electrical for the fuel system part i also had the idle speed adjusted and no results. The problem is that it jumps some times but not all time I take it in to a mechanic and it does nothing wrong. Did that test for codes on the check engine light and came up with code 2 and found a book that labeled it as crankshaft position sensor or idm (identity theft management) witch as far as I know is an anti theft system right?Chuck
91 GL -Ol' Rusty
93 GL - Lil Red
91 L - Tweetystiva
one of the Festiva's came with anti theft devices, so CPS is more likely, although as I was reading, I was thinking it sounded like a throttle position sensor....
I do believe the CPS is part of the distributor...Contact me for information about Festiva Madness!
code 2
Code 02 (two short output signals) is the crank angle sensor.
Code 20 (two long output signals) is injector #3
For 02
1. Check distributor circuit for poor connection
2. Check if code No. 03 is also present
3. Check ECU terminal 31 (B/LG) to ground for continuity
4. Check if battery voltage exists at distributor terminal B when ignition switch on
5. Check terminal wire between distributor terminal and ECU terminal 33 for continuity
6. Check if ECU terminal 33 voltage is O.K.
7. Check if 0V or 5V exists at distributor terminal C
8. Check if 5V exists at ECU terminal 33. (with distributor connector disconnected)
Note: Step 7 involves replacing your distributor and step 8, replacing your ECU. Let's hope it doesn't get to that.
Cold's not bad. It was the 1/2" of ice on everything this morning that was the killer...Originally posted by Jacob View PostOk, thanks for all your help but the weather turned to cold for us so it will be a few days before the test gets done. Thanks againChuck
91 GL -Ol' Rusty
93 GL - Lil Red
91 L - Tweetystiva
"Identity theft management" sounds to me like VIN numbers put in some out of the way places. I have never heard of any factory anti-theft features (besides the normal key locks) for Festivas.
Nope. I googled "ford idm" and got this thread from another forum:
I believe that the IDM has gone out in my truck. I was wondering about the location and any instructions to change it out Thanks in advance for any info.
IDM is "injector driver module."
New one for me!
holy crap.....how many of these are messed up on our vehicles (if so equipped) that we had no idea about......sheeeeesh!Originally posted by Safety Guy View Post"Identity theft management" sounds to me like VIN numbers put in some out of the way places. I have never heard of any factory anti-theft features (besides the normal key locks) for Festivas.
New one for me!
Karl"FLTG4LIFE" @FINALLEVEL , "PBH"
Would an IDM be in each injector or a separate part?
I think from what is being posted that it is a module that controls the injectors"FLTG4LIFE" @FINALLEVEL , "PBH"
*none*Originally posted by scitzz View Postone of the Festiva's came with anti theft devices, so CPS is more likely, although as I was reading, I was thinking it sounded like a throttle position sensor....
