I can't check this stuff because my parents are being stupid. They wont let me use there tools and equipment. So it will be a little while longer before I can get you answers. But I do know that it does run better in the cold before the engine is warmed up if that helps anything.
Repair help
I'm betting crank position sensor. I'll bet once it gets warm, it goes flaky.Festiva: Because even my dog can build a Honda.
Search function!
We have a search area and you will find what you are looking for there.Dan
It's part of the distributor and is actually a camshaft position sensor on Festivas. It's not replaceable (as far as I know). If you have a known good distributor, try it. Otherwise you'll need a new distributor.Originally posted by Jacob View PostSounds worth checking. But idk how to get to it. Anyone have knowledge they can share?
I'd try everything else first though. My diagnosis is just an educated guess from working on other cars.Last edited by JPT; 01-19-2011, 02:04 PM.Festiva: Because even my dog can build a Honda.
go to the first blue bar that spans the entire length of the screen you will see the word "search"..... all other instructions are self explanatory past this minor step...Andrew Walker
Current Daily Driver:
89 Nissan D21 SE V6 5 speed 4x4
Projects in the works:
84 Mercedes Benz 300D(T)(Baby) currently awaiting transmission transplant/ full on restoration
Best guess
My best guess is that you have a crank position sensor (in the distributor)that has gone bad. What happens is that when it gets warm/hot from eng heat, it stops sending signal to the pcm that the eng is still turning. Not a servicable part, must replace distributor.186,000 miles per second is not just a good idea, it's the law
1990 yellow L+ (l8ly)
1990 yellow L+ (sunryz)
1992 aqua L (agua)
1993 blue L (aurora)
Any idea were I can find a distributor?Originally posted by hot4dl8ly View PostMy best guess is that you have a crank position sensor (in the distributor)that has gone bad. What happens is that when it gets warm/hot from eng heat, it stops sending signal to the pcm that the eng is still turning. Not a servicable part, must replace distributor.
Ya know I offered to help you the first time you posted. You blew me off. I live in Rapid City, and have parts.Chuck
91 GL -Ol' Rusty
93 GL - Lil Red
91 L - Tweetystiva
Alright, I finally got some progress after all this time, I have not yet been able to check the camshaft possition sensor itself yet but i do know that the Throttle possition sensor at the very top of the engine can be disconected without any problems to the engine, which throws my mind out. I alwasyse thought an engine would not run without it being plugged in. my current plans are to get the fuel pump taken in and checked and change the brakes.thanks again for All the assistance
And hotfordcat please pm me for assistance, thanks
I found out today that the thermostat does work, It stopped working awhile back, so I put a new one in and it seemed not to work. but today it worked and I found out that when its in neutral and you push on the gas, rev it up (it sounds great) the thermostat rises by a jump, but then it goes down when the gas is released.
