This problem just started. When I come to a stop & put in the clutch the engine cuts off. No smoke, studdering, or anything , just shuts down. Can restart with no problem & idels okay . '93 EFI, 5 sd. Always starts fine, if I down shift all the way to 1st it won't happen. New fuel filter about a month old, can,t find a vac. leak.:sad4: I did search, could find no problem like this listed,been lokin' for a few days.
Engine Cuts Off
check for sticking VAFTrees aren't kind to me...
Mine randomly does the same thing. It will go days without doing in it, then sometimes do it a few times in the same day.Rick
1993 Ford Festiva
2000 Ford E350
I think you solved your own problem vertical vaf no good93 L B6T DD http://www.fordfestiva.com/forums/sh...ad.php?t=37751
RJ
Randon stralling is a symptom of a failing ignition control module. Don't know if it makes sense in tiis case but they can be taken in to some parts stores and tested for free.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Next time it happens don't start it, just turn the key to the run position.
Does the check engine light come on? if yes I would look at the ignition module, if no then most likely a VAF going bad.
I went through this awhile back.Hotrod Forums Directory * D&D Discbrakes 61-67 Econoline Conversions
Originally posted by navdoc101 View PostThanks. I have an extra VAF if that turns out to be it.93 L B6T DD http://www.fordfestiva.com/forums/sh...ad.php?t=37751
RJ
Originally posted by navdoc101 View PostIts still happining, but only after engine heats up. Kinda random.Trees aren't kind to me...
Fixed it, I hope. It was my own fault. When I first got 'Tiva & did not have a manuel I tried to adjust the idle . I did it with no jumper. I know DUMB!!. I made a jumper last night & re-set idle this morning. Took it for a drive & seems to be okay. I forgot about adjusting the idle. Thanks Festyboy for joggin' my failing memory.:notworthy:
