Engine Cuts Off
  • Engine Cuts Off
    This problem just started. When I come to a stop & put in the clutch the engine cuts off. No smoke, studdering, or anything , just shuts down. Can restart with no problem & idels okay . '93 EFI, 5 sd. Always starts fine, if I down shift all the way to 1st it won't happen. New fuel filter about a month old, can,t find a vac. leak.:sad4: I did search, could find no problem like this listed,been lokin' for a few days.
    '93 Green L - ' Tiva
    check for sticking VAF
      Will do. Thanks!
        VAF gate moves fine. Did have VAF canted almost vertical from normal. Adjusted it back horizontal, I'll see if that helped tomarrow when I drive. Its been like that for several months with no problem,( that I know of).
          Mine randomly does the same thing. It will go days without doing in it, then sometimes do it a few times in the same day.
          Rick
          1993 Ford Festiva
          2000 Ford E350
            I think you solved your own problem vertical vaf no good
            RJ
              I always thought a vertical vaf WAS good!:p:confused4::blob6:
                Its still happining, but only after engine heats up. Kinda random.
                  Randon stralling is a symptom of a failing ignition control module. Don't know if it makes sense in tiis case but they can be taken in to some parts stores and tested for free.
                    Next time it happens don't start it, just turn the key to the run position.
                    Does the check engine light come on? if yes I would look at the ignition module, if no then most likely a VAF going bad.
                    I went through this awhile back.
                      Thanks. I have an extra VAF if that turns out to be it.
                        have you fixed the problem yet or no?
                        RJ
                          just answered your own question.... one of 2 things, idle screw mis-adjusted (doubtful, but possible), OR sticking IAC stepper motor (more likely). the IAC stops being used once the engine is up to temp, all idle speed control is then taken over by the dashpot (to keep the throtle plate from slaming shut) and the idle set screw.
                            Fixed it, I hope. It was my own fault. When I first got 'Tiva & did not have a manuel I tried to adjust the idle . I did it with no jumper. I know DUMB!!. I made a jumper last night & re-set idle this morning. Took it for a drive & seems to be okay. I forgot about adjusting the idle. Thanks Festyboy for joggin' my failing memory.:notworthy:
