Check spark by putting a screw driver in each plug wire (one at a time) and setting it next (about an 1/8 inch away from something metal (ground) and have someone crank the engine.
stupid problem with festiva
wow, you're such a wuss!!! you don't have spark because you don't have spark CONTROL.
you have one of 3 issues:
1) the most common problem is oil contamination in the dizzy pick up sensor. solution is to hose down the inside of the dizzy with brake clean and let dry.
2) you have a bad ignition modual in the dizzy
3) you ahve a bad pickup in the dizzy
also check the ground contact at the little black sensor right next to the coil, it can cause super weak spark and no start conditions.
and if you REALLY want to sell it, i'll give you 300 for it.Trees aren't kind to me...
does a B6 disty have the same type of rotor as a Festy....3 positions....only 1 works?"FLTG4LIFE" @FINALLEVEL , "PBH"
yeah it does IIRC but you'd still have spark, just at the wrong time.Trees aren't kind to me...
i called dibs first! lolOriginally posted by Zanzer View PostI'll give you $300 and I can pick it up tomorrow. I'm in NC
I hope you don't give up on the Mustang this quickly if something goes wrong. Most car problems are pretty simple to figure out, but you need some patience!Originally posted by 93festiva1 View Postim so done with this car guys im sorry but im getting a mustang tomarrow so if someone wants to buy this car make me a nice offer it ran dame good before this has the b6 in it
i'm with you on this one! maybe you could hold it till madness??? lolOriginally posted by Zanzer View PostHehehe I'm closer LOL :p
I don't car who gets it...I just don't think it needs to get crushed :???:Trees aren't kind to me...
ill trade you this like new yamaha scooter for it! gets 80 mpg & runs great only 500 original miles. 2000 model title coming soon but you can ride it as a moped as long as you dont drive it over 35mph (in n.c.) easily worth 1200.00Never Hire a Boy to do a Man's Job!!
Originally posted by FestYboy View Postwow, you're such a wuss!!! you don't have spark because you don't have spark CONTROL.
the icm is on the outside of the car i replaced that the dizzy is all nasty on the inside not from oil thou im thinking its the dizzy that is the problem im going to try and find one sooner or later
