Alright, I'll hotwire the ignition first, then. I figured it would crank without it...
Help me get it started
Pull out a spark plug, attach it to the wire, and place it close to a good ground, say, the block? less than an inch away. Avoid bright light at first, then with the key fully in the "on" position, crank the engine over with the push button. Watch the plug to spark to the block, while holding a finger close to where the plug came out of the cylinder head. You should get a wet finger from the fuel spurting out and see spark from the plug. A lack of either will help narrow down the next step....Contact me for information about Festiva Madness!
Originally posted by Basement_Modder View PostI am cranking it with a button. There's no ignition switch, lol. New timing belt on it, too. Just added gas. Filter is clogged, but I have a new one for it I'll be adding asap.It was a joke- Try the "EASY" button next.Originally posted by Basement_Modder View PostThen it wouldn't crank.
Its between +12v on the battery and the positive side of the starter solenoid.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Turns out they were already getting power. Now I got it started with the button and it ran a little bit, but the idle was too low, and I had to rev it to keep it going. It was turned off, gas was added, and then it refused to ever start again. How do I set the idle (Pics PLEASE) and what do you think the issue is now?
Edit- It has a new fuel filter now, too.1990 White L-Plus 5-speed rust-machine
Scrapped
1991 Blue L 5-speed
daily driver, intermittent project
1993 rustless wonder
A shell, awaiting suspension, brakes, and B6T
Yeah, that.Originally posted by scitzz View PostPull out a spark plug, attach it to the wire, and place it close to a good ground, say, the block? less than an inch away. Avoid bright light at first, then with the key fully in the "on" position, crank the engine over with the push button. Watch the plug to spark to the block, while holding a finger close to where the plug came out of the cylinder head. You should get a wet finger from the fuel spurting out and see spark from the plug. A lack of either will help narrow down the next step....Contact me for information about Festiva Madness!
Also, what does the oil look like? And the radiator fluid?Contact me for information about Festiva Madness!
Some days I am a moron. I really mis read his last comment.Contact me for information about Festiva Madness!
I would first listen for the fuel pump. Check to see if the inertia button has popped.... If it did reset . If all else fails check for power at your EFI main relay ( yellow 5 pin plug) Probe the yellow/blue wire to see if you have 12v as it controls fuel and spark and without that you have nothing...
Yank the fuel line and make sure you have good fuel pressure. If you have good fuel, spark and timing is right there shouldn't be a reason for it to not start back up. Like stated above check the EFI relay, also check the EFI fuse in the fuse box. Not sure if its labelled EFI or just ENGINE.Last edited by 91_festy_Gl; 05-31-2011, 04:08 AM.89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
My site: 20tessa.sytes.net
me
