Hey guys just need to find out how much coolant a '93 GL holds.
Coolant quantity
Pour it in till its full.....lol....sorry, couldn't resist.
I am sure someone will come up with an answer for you soon. I would look but I am not sure where my manual is right now."FLTG4LIFE" @FINALLEVEL , "PBH"
Haynes manual:
5.3 qt, 5.0 litre - '93 and earlier
5.8 qt, 5.5 litre - '94 and later
6.3 qt, 6.0 litre - '94 and later with A/COriginal owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
If your water pump is leaking coolant out the weep hole at the top, I wouldn't even bother getting anti-freeze until you replace the pump. Just use distilled water at $1/gallon.Originally posted by crusher773 View Postthats just wanted to know how much anti freeze i needed to buy today. I have a water pump sounding awful.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
If it's making noise then I'd say it's living on borrowed time and probably a good idea to go ahead and replace it. If your luck is like mine it will go out on you when you're the furthest point away from home, tools, garage, etcOriginally posted by crusher773 View PostI have a water pump sounding awful.
LOL
