Coolant quantity
  • Coolant quantity
    Hey guys just need to find out how much coolant a '93 GL holds.
    1993 Festiva GL The Besty Festy
    Pour it in till its full.....lol....sorry, couldn't resist.
    I am sure someone will come up with an answer for you soon. I would look but I am not sure where my manual is right now.
      5/8 gallon of full strength anti freeze and the rest water or about 1.25 gallons of 50/50 premix.
      WWZD
      Zulu Ministries
        Haynes manual:
        5.3 qt, 5.0 litre - '93 and earlier
        5.8 qt, 5.5 litre - '94 and later
        6.3 qt, 6.0 litre - '94 and later with A/C
          thats just wanted to know how much anti freeze i needed to buy today. I have a water pump sounding awful.
            If your water pump is leaking coolant out the weep hole at the top, I wouldn't even bother getting anti-freeze until you replace the pump. Just use distilled water at $1/gallon.
              If it's making noise then I'd say it's living on borrowed time and probably a good idea to go ahead and replace it. If your luck is like mine it will go out on you when you're the furthest point away from home, tools, garage, etc LOL
              WWZD
              Zulu Ministries
                any secrets on getting the drive axel oil seal out?
