Well glad it is running okay. So do you think it was either a clogged radiator or possibly the radiator cap being buggered caused a problem with flow somehow?
Bp swap overheating
a bad cap won't allow pressure to build to keep system from boiling (remember that for every 1lb of pressure, your boil point raises 3*). so as soon as the enging reached temp, it boiled internaly, which causes air pockets, which makes thing worse and the engine overheats.Trees aren't kind to me...
I made sure the radiator wasn't clogged when I drained it so I think the cap had something to do with itOriginally posted by Gforcefd View PostWell glad it is running okay. So do you think it was either a clogged radiator or possibly the radiator cap being buggered caused a problem with flow somehow?"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
You beat me to it Arty! I'm thinking that was the problem because the cap was in rough shapeOriginally posted by FestYboy View Posta bad cap won't allow pressure to build to keep system from boiling (remember that for every 1lb of pressure, your boil point raises 3*). so as soon as the enging reached temp, it boiled internaly, which causes air pockets, which makes thing worse and the engine overheats."Lane, I've been going to this high school for seven and a half years. I'm no dummy."
