Finally started driving the grey festy today and within 15 minutes it started getting really close to overheating. The rad. Fan wasn't running so I unplugged it to stay on constantly (that's how it was when I got the car btw). Anything I'm missing out on with the bp swap/rad fan/temp sensor etc. I don't want to miss the upcoming 4thtiva meet so please help a brother out! Also, I did do a quick search but I'm in a rush to get to work and couldn't read through all posts.
Bp swap overheating
Bp swap overheating
Gone but never forgotten, "Hulkstiva"...http://www.fordfestiva.com/forums/sh...ht=progressionTags: None
Originally posted by denguy View Postbubbles in the rad = blown hg."Lane, I've been going to this high school for seven and a half years. I'm no dummy."
what thermostat temp do you have? i know B3's had 185 and 195 F thermostats, but don't know about BP.
-Aspire brake swap COMPLETE!
Cody, how are you measuring temp? I wouldn't trust the stock temp gage. When i put my bp in the gage was high. I swapped in the sensor (in thermostat housing) with my festy one(started reading normal). I also have a mechanical gage.-Greg
Redneck Engineer
FOTY - '09
If you keep your hand on your rad hose and rev the motor does the hose expand?
If so there's pressure in your coolant system (usually head gasket)
Why not run the fan on a toggle, or constant I might just do that with my swap, but I live in S FL it's always 90 + degrees
X2 On what Greg said I've heard that the Festiva temp sensor is accurate
Originally posted by M3NTAL View PostIf you keep your hand on your rad hose and rev the motor does the hose expand?
X2 On what Greg said I've heard that the Festiva temp sensor is accurateI know its a piece of crap but im still faster...and its 100% legal!!!!!
Originally posted by ejp2fast View Postwhat thermostat temp do you have? i know B3's had 185 and 195 F thermostats, but don't know about BP.
Originally posted by eurotiva View PostCody, how are you measuring temp? I wouldn't trust the stock temp gage. When i put my bp in the gage was high. I swapped in the sensor (in thermostat housing) with my festy one(started reading normal). I also have a mechanical gage.
X2 On what Greg said I've heard that the Festiva temp sensor is accurateLast edited by lanemeyer14; 06-29-2011, 12:23 PM."Lane, I've been going to this high school for seven and a half years. I'm no dummy."
Originally posted by kartracer46 View PostYou may want to check the temp sensor on the head, if not I have had several that I have just hooked up a toggle switch.
Also, was your 15minute run with or without the fan running continuously?Last edited by lanemeyer14; 06-29-2011, 04:13 PM."Lane, I've been going to this high school for seven and a half years. I'm no dummy."
sounds like a headgasket, especially if its mixing oil and coolant like that.89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
he said brown, not thick and milkshake like. i would suspect the fresh coolent has released some scale and rust from the system and is keeping it in suspention (like it should).
what's your timing look like and are you running an auto rad or manual rad? (should run an auto rad).Trees aren't kind to me...
Originally posted by FestYboy View Posthe said brown, not thick and milkshake like. i would suspect the fresh coolent has released some scale and rust from the system and is keeping it in suspention (like it should).
what's your timing look like and are you running an auto rad or manual rad? (should run an auto rad)."Lane, I've been going to this high school for seven and a half years. I'm no dummy."
Your rad might just be clogged. A new one cured my Festy's overheatig problem.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
