doesn't work in neutral either , and i tried moving the shifter a few times, nothin, and the e-brake light comes on when you turn the key forward for start, which i think indicates an interlock issue (i think), that light ususally doesn't illumanate during a normal start
starter issues
have you tried replacing the middle fusible link on the drivers side strut tower. If it is bad it will still let all the lights come on but will not engage the starter. It may also just be corroded if not bad. Just a thought."FLTG4LIFE" @FINALLEVEL , "PBH"
i was actually going to splice in the extra start wire just before the original spade connector for the starter, makin a "Y" into the starter, so I can start it normaly (once fixed), and use the extra wire as and emergency start, i just have to make sure the key is forward so the pump and accessories are on to start it in "emergency mode".Last edited by funky technician; 11-01-2011, 06:16 AM.
No need for any black tape if you get one of those 50 cent adapters.Originally posted by funky technician View Posti was actually going to splice in the extra start wire just before the original spade connector for the starter, makin a "Y" into the starter, so I can start it normaly (once fixed), and use the extra wire as and emergency start, i just have to make sure the key is forward so the pump and accessories are on to start it in "emergency mode".
Sapde terminal
Had the same issue.It was crappy corossion on the Male/female solenoid connection. Spliced in a new female connector.Cleaned male & "tinned" it with solder. Never did it anymore. If it did it with a different starter like you said. I would look real closely at three things. Battery connections @ the posts (shouldnt be able to move them by hand).Neutral safety switch. And feamle spade connector @ solenoid.Last edited by nitrofarm; 11-01-2011, 02:52 PM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
well, you hit it, the solonoid is frozen in place, i did my jumper thing, and same thing, just clickes a bit, so the starter is garbage, i cleaned the contacts not long ago on the solonoid so its not the contacts, and i tried tapping it, nothing, so i'll look at gettin a new starter/this one re-builtOriginally posted by nitrofarm View PostHad the same issue.It was crappy corossion on the Male/female solenoid connection. Spliced in a new female connector.Cleaned male & "tinned" it with solder. Never did it anymore. If it did it with a different starter like you said. I would look real closely at three things. Battery connections @ the posts (shouldnt be able to move them by hand).Neutral safety switch. And feamle spade connector @ solenoid.
Sounds good-Last edited by nitrofarm; 11-01-2011, 07:43 PM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
