Aspire CV axle removal
  • eurotiva
    replied
    Get a bigger hammer Tom.
  • TominMO
    replied
    Originally posted by eurotiva View Post
    I have a screwdriver that will go around the diff pin and I have had to drive them out from the opposite side.
    I have also gotten a strap around the inner cup and had someone pull it while i beat on a prybar (this was recent on the focuss)
    Really stupid design, to be held up by a faulty C-clip. I've probably screwed up the seal by now too, so there's no going back.
    I've had Toyotas and VWs on which you only had to undo six bolts on each side to get the axle off. Super-simple. Even Subarus with roll pins are a lot easier.
  • invader_star
    replied
    I think God is pissed at me because I don't believe in Him.
    :lol:
  • eurotiva
    replied
  • TominMO
    replied
    Originally posted by shadetree View Post
    1. This takes two people, stick your prybar in behind the axle cup and the trans and pry out on the axle. Then the other person holds the axle up streight and compressed, then knock it on the end with a hammer like your driving it back in the trans. This will shock the c clip and it should pop out .
    2. If not, pull the other side and run a very thin bar through the trans and drive it out. good luck
    1. Might work, I'll try it.
    2. What makes you think the other side would come out any easier?
    diff pin will keep you from reaching the other axle. we have a protege DX (B8 ) and the same thing is the issue. apparently there was at one point a rash of circlips that were not shaped properly and they were causing the same issue. had to remove the circlip from inside the trans with a dentist pick and thin punch... not fun.
    Sounds like you're saying I have to remove and dismantle the trans to get at it. Any chance it can be accessed from the filler hole/speedo drive hole? Or the drain plug?
  • FestYboy
    replied
    diff pin will keep you from reaching the other axle. we have a protege DX (B8) and the same thing is the issue. apparently there was at one point a rash of circlips that were not shaped properly and they were causing the same issue. had to remove the circlip from inside the trans with a dentist pick and thin punch... not fun.
  • shadetree
    replied
    This takes two people , stick your prybar in behind the axle cup and the trans and pry out on the axle . Then the other person holds the axle up streight and compressed , then knock it on the end with a hammer .like your driving it back in the trans . This will shock the c clip and it should pop out . If not , pull the other side and run a very thin bar through the trans and drive it out . good luck
  • TominMO
    started a topic Aspire CV axle removal
    Been trying for two days to get my Aspire driver side CV axle out of the manual tranny. Things I have tried:
    1. pulling
    2. inserting large flat screwdriver, and pulling
    3. inserting prybar, and pulling
    4. hitting prybar with mini-sledge
    5. repeatedly rotating slightly, then #4, trying to find where the clip is open
    6. bargaining with God
    7. Buddhist chanting
    8. becoming one with the axle
    I have the Haynes manual and Festiva manual. No help. I also did a search and read what other people have done.
    Any thoughts?
