Originally posted by zoom zoom
Aspire CV axle removal
My HF slide hammer was $60.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Latest issue. I notice that the Aspire's new driver's side axle seal is leaking. Tmw I will pull the speedo drive to see how much. I have about 200+ miles on the car since I did the axle.
What would make it leak? Just trying to get some ideas to speed things up a little tmw, and not be reinventing the wheel so much.
The new pass. side seal seems nice and dry BTW.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
This is a new seal I put in after removing the old axle, then I installed the new axle.Originally posted by neanderpaul View PostDamaging the seal when removing the axle will cause it to leak. It happened to me on my axle thread thread.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I tried to be careful; lubed the seal where it would contact the axle; and lubed the axle where the seal would go on too, to make it all slide easily, with no friction to bind the seal up. Maybe something will be obvious when I closely inspect it tmw.Originally posted by neanderpaul View PostMy bad. If you damaged the surface the seal sits in it can cause it to leak.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
also, if the seal wasn't seated straight, the actual sealing surface will be skewed and will cause a leak. And, if the seal is installed properly, there can still be a leak due to defect OR scuffing the seal by not lubing the unput shaft before insertion.
i type slow...Last edited by FestYboy; 09-19-2011, 09:21 PM.Trees aren't kind to me...
Thanks, tried to be careful to install it straight, and did lube the input shaft. Maybe something obvious will jump out at me tmw.Originally posted by FestYboy View Postalso, if the seal wasn't seated straight, the actual sealing surface will be skewed and will cause a leak. And, if the seal is installed properly, there can still be a leak due to defect OR scuffing the seal by not lubing the unput shaft before insertion.
i type slow...
Was considering driving it to Madness instead of the Festy, but not so much now. Plus the Aspire leaks at the front crank seal.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
bring the aspire... we'll fix you up there!Trees aren't kind to me...
Ooooohhh, now we're talking! I'll bring the new parts.Originally posted by FestYboy View Postbring the aspire... we'll fix you up there!90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
good! we'll have LOTS to talk about....Trees aren't kind to me...
Checked out the left axle seal, and its leaking from the inner part where it contacts the axle itself. So it's probably skewed a little. But when I checked the fluid level, it was fine, after 200+ miles of driving; so no worries driving it to Madness. I'll just check it twice on the way. My motor oil leak is minor too; probably won't have to add any, or very little, until I get there.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Whats Madness ? Never mind I just answered my own question.Sounds like an awesome good time! My wife's brother lives in Raliegh.If I had a brain I could have tricked her into going. Snap! Not to mention its changeover week for me at work. Meaning I have 7 days off in a row :banghead:Originally posted by TominMO View PostThanks, tried to be careful to install it straight, and did lube the input shaft. Maybe something obvious will jump out at me tmw.
Was considering driving it to Madness instead of the Festy, but not so much now. Plus the Aspire leaks at the front crank seal.Last edited by Pu241; 09-20-2011, 07:34 PM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
then what's stopping you???!!Trees aren't kind to me...
