Try a fuel pressure reading . Cycling the key all your doing is making the fuel pump run constant again ... Sounds like a fuel pressure issue to me . Might even be a vaf door problem . Pm your address and ill send you a vaf if you wanna try that .
Could also be tps problem ,have a friend that went through three vaf (warranty replacement )only to find cure to be tps . I'll send a complete throttle body as well .
