Two glasspacks sound?
  • Two glasspacks sound?
    Right now I have a single 25 inch Cherry Bomb glass pack, no cat and straight pipe, and a 2.25 inch down pipe exiting out the side and it is too loud. Does anybody know if I put another glass pack in line if it will significantly reduce the sound level? I am thinking of installing a shorter 2.00 in/out glass pack to add a "little" back pressure.
    Semper Fi til I die!
    1993 Fescort GT 1.8 BP automatic Kia Rio front struts and cut springs Cut Front Festiva springs with Monroe Aspire struts in rear
    Bebandit has a glasspack where his cat used to be, and another glasspack down the line. It's louder than stock, but has presence. His exhaust exits the back of the car.
      im running 2 glass packs and mine is pretty quiet... im also turbo BP though
        Great answers, I'll have to put another one on, thanks!
          yes, adding a second, slightly smaller glasspack will significantly reduce the sound, and NOT add very much backpressure. There's a whole description of the physics of fluids and flow as to why, but I'll save that for another time.
          Jim DeAngelis
            They used to add glasspacks to replace the cat(s) on the mustangs at the racing schools. Made them sound really aggressive but not deafening.
            1993 GL 5 speed
              i may have to try this mines to loud for my taste. i have a resonator and a dtm and even with the resonator its too loud for me.
              -90 festiva - bp swap "relentless" (thanks matt) aspire swap, pacesetter, underdrive pulley
              -90 festiva - surf blue (undetermined destiny) wanna keep but wifey says noooooooo
                I use a GP in place of the resonator and a cheapo turbo muffler. Sounds pretty good, I think.
                Jim DeAngelis
                  I was thinking the 2 incher would help illeviate some of the noise and perhaps add a tiny bit of back pressure. Please explain, FB71, the flow dynamics sounds very interesting!
                    got a couple hours of spare time? lol it's deep stuff.
                      he def is the master and could explain it
                        TWO 18" Glass packs
                        How do you guys think two 18" glass packs will sound? I want to eliminate the cat & just go with two packs. I just dont want it too loud.
                          if your car is too loud just add a turbo... they work great for noise reduction
                            Yeah turbos make great mufflers!! It worked great to quiet down my noisey exhaust on my element
                              I'll film a vid of my current set up with one glass pack and saturday or sunday I'll film it with two glass packs and let you compare.
