^^what he said
You may also want to install a new fuel filter as added insurance. It does sound like a fuel mixture issue and not just a timing issue. That explains why it wouldn't ping when it was cold....since the fuel mixture is fat during warm-up mode.
Pull the plugs out as well and take a look at them. They can give you some good info about what's going on during the combustion process.
One other possibility...is there a lot of blow-by, or a lot of oil in the air intake tube that goes from the VAF meter to the throttle body? As these cars age, they develop blow-by and can blow some oil into the air intake tube via the PCV fresh air hose. If this oil builds up in the tube, it can run down into the VAF meter and/or even run back into the throttle body. When that happens, it will ping like crazy.
