"Speedo" could be many things. Most likely the cable broke in which case you will have to try to track down a used one that is complete sheath and cable, or cable only. A very long extension and 10mm socket will allow you to undo the sending unit at the very back of the engine so that you can get at the cable connection. I had the nylon gear wheel on the unit inside the transmission split at one time. Have also had situations where the actual instrument panel developed a jumping indicator. A replacement instrument panel (which is not a big job) fixed that.
Need more info....what broke? What are the symptoms?
91GL Green Auto DD There ain't no rest for the wicked
until we close our eyes for good. I will sleep when I die!
The odometer works off the cable as well......... first thing i would do is remove the speedo cable from the car, spin the gear on the transmission end of the cable and see if it spins at the cluster end of the cable, that'll tell you if the cables good or not
If the cable is good, you'd be able to stick your finger in the transmission where the cable goes and feel the speedo gear, if you can not spin the gear with your fingerand the teeth on the gear are good, then thats not the problem
If the cable and gear turn out to be good, then chances are you need a new cluster
~Jeff
1988 Festiva LX Silver 5speed. 219,000 miles. My new daily driver.
1988 Festiva L Plus Red 2brl 4speed. 504,477 miles and holding till I get the speed-o fixed.
2003 Mustang GT 5speed
Here is a picture from the Haynes Manual.
The view is from underneath and behind but it can be accessed from above just as easily.
The bolt is to the left of the cable when standing in front of the car.
It will take a lot of force to remove the cable from the transmission but make sure you don't pull on the cable sheath or you may break it. I made this mistake once..
Here are some Festivas in the area.
Speedo cable is about $12 if you need one.
