No need to remove air cleaner. On the driver's side of the air cleaner is a white metal box with two large hoses coming out of it (Ford's pulse air system). Your small hose with the check valve on it plugs in under the rear big hose. There are two more small vaccum hoses under there, behind that one. The one you ask about is closest to the front of the car of the three.
Dangaling hose
Originally posted by WmWatt View PostNo need to remove air cleaner. On the driver's side of the air cleaner is a white metal box with two large hoses coming out of it (Ford's pulse air system). Your small hose with the check valve on it plugs in under the rear big hose. There are two more small vaccum hoses under there, behind that one. The one you ask about is closest to the front of the car of the three.
sent from my EVO in my Festiva
