Radiator ?
  • Radiator ?
    I believe Justiva the justifiable Festiva may be done for. Today I checked the coolant. And what did I find? Low on coolant and a white milky liquid in it and around the radiator cap.
    What might this be?
    sent from my EVO hacked with Vaelpak GB AOSP with Tiamat 3.3.7 Kernel
    First time owner
    89 L carb'd - white / still needs work
    Bought for mpg and only paid $250
    got a picture?
    Walth
    Festiva #1: 91 Red L 4/5
    http://www.fordfestiva.com/forums/sh...ad.php?t=27981
      Can't get a good picture, but its oil
      First time owner
        Head-gasket replacement doesn't mean your festiva is "done for".
        It's a relatively straight forward process and can be accomplished by a novice in a full day.
        Provided, you don't have issues with corroded fasteners.
          Lol. Corroded fasteners!! I know it will be a problem then.
          First time owner
            well...corrosion and hopefully no issues with the head
            Walth
              What parts do I need to purchase? How much cost am I look at? Should I try and do it myself? And do I need a helper?
              First time owner
                Oh. And can it be a intake or exhaust gaskets?
                First time owner
                  Head Gasket...you can do it yourself...head gasket kit.
                    And its my daily car. Can I still drive it? I'm so confussed
                    First time owner
                      A head gasket set for your car in your area at Advance Auto is around $100. A novice should be able to do this job by himself in a day. For $100, I would definitely attempt this, and not let Justiva go by the wayside.
                      http://www.cardomain.com/id/hawkdoc60
                      01 Chevy Impala 9C1 police package "Unnamed yet". 154K
                      88 LX 5 speed "Silver PHOENIX" Currently being rebuilt inside and out. 400K
                      88 L 4 speed "Cherry Bomb" saved from the car crusher just in time. 186K
                      06 Ford F-150 Pickup Replacement for my 2001 Impala Cop Car that lunched its engine.
                        Your in TX for john's sake how much corrosion could you possibly have!
                        No, but you will need to replace them when you do the head gasket, if that is the issue.
                        It is possible you just have coolant leak, but if after you clean out the radiator the milky liquid returns in same or similar volume, then likely a head gasket.
                        Are you losing oil too?
                        Wipe out the milky liquid refill with coolant and see how long before it returns, if it returns.
                          I've been losing oil since I've had the car in March. But it was never in radiator.
                          Do I need head gasket set or just head gasket
                          First time owner
                            you're going to be taking apart places that have gaskets in them that can't be resealed properly with the old gaskets. the gasket set is the best way to go.
                            is this your only car? period? have anyone that can give you a hand with it? Or possibly a ride to a machine shop or parts store if need be?
                            before you start getting into doing this yourself, which is never a bad idea btw, please do read the haynes manual for rebuilding your engine.
                            Walth
                              My wife has van. Its for kids to school, games,etc.. so can't take it from them for work. But yes to auto part store etc.
                              First time owner
