HI , I've got a 93 festiva with a leaky master brake cylinder. When the resevoir got low i would add some dot 3 fluid and everything would be fine for a while. I hadn't driven the car for a couple of weeks and decided to take it for a run tonight. I tried the breaks and nothing - the pedal went straight to the floor. I popped the hood and checked the resevoir and it was empty. I filled it up and tried the brakes again... nothing. I'm not sure but is the reason my brake pedal goes to the floor is that air got into the line? If so, will bleeding the brakes fix the problem?
I've got a new master brake cylinder now and plan to install it this weekend. I've never done this before and would greatly appreciate some guidance. And the bleeding, does that go hand in hand with installing the master cylinder? I need help bleeding too if its needed. thanks.
