If you need to fix the LCA boot, then do it Geneva's way. I just like taking off the strut bolts instead because they're usually easier than getting the pinch bolt loose and the LCA down with all the rust.
g00db0y, I'll have to take a look at what you listed for all the other problems later, but a lot of what you listed is pretty easy to tackle.
