This looks like its going to be fun, ha
Clutch Return Spring
I would think that spring merely gives you the 1/2 inch or so of "free play" in the clutch pedal travel before it starts pulling on the cable.
Shouldn't the big spring hooked onto the clutch actuator arm on top of the gearbox keep any pressure off the throwout bearing when you're in gear?88L black, dailydriver
88LX silver a/c, dailydriver
4 88/89 disassembled
91L green
91GL aqua pwrsteer
92GL red a/c reardmg
1952 Cessna170B floatplane
I thought he was referring to the spring on the Bell Housing.My Bad,didnt read the post enough. And I'm sure you are correct @ the free-play. Like the spring simply supports the weight of the pedal assembly so its not actually applying any load to the clutch?Originally posted by AlaskaFestivaGuy View PostI would think that spring merely gives you the 1/2 inch or so of "free play" in the clutch pedal travel before it starts pulling on the cable.
Shouldn't the big spring hooked onto the clutch actuator arm on top of the gearbox keep any pressure off the throwout bearing when you're in gear?Last edited by nitrofarm; 12-02-2011, 11:53 PM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
That's what Iwas thinking too. It seems semi-pointless. Bungee cord solution FTW!Originally posted by nitrofarm View PostI thought he was referring to the spring on the Bell Housing.My Bad,didnt read the post enough. And I'm sure you are correct @ the free-play. Like the spring simply supports the weight of the pedal assembly so its not actually applying any load to the clutch?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Interesting! Does it look like a factory setup or something some PO came up with ? I'm thinking that 88FestivaLX could come up with a similar creative solution.Originally posted by Bert View PostTominMO's picture of clutch return spring from a 91 manual is different from the one in my 93. Picture shows a spring installed right on the shaft whereas in my car it is a tension spring hooked from the pedal to a tab on the dash frame.Last edited by TominMO; 12-03-2011, 09:46 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
