I recently pulled the 93 automatic GL out of retirement. The low beams used to flicker occasionally. I unplugged and replugged the "head" fusible link. That fixed it for a while. But occasionally they would flicker. I decided to replace the links with cartridge fuses. I used 30/40/30. They worked. I flashed my high beams at ironically a festiva with no headlights last night. When I did my low beams went out. I stopped unplugged and replugged the fuse. They came on. I stopped for an hour. Then the next time I started it up the low beams would not work. I stopped and got electrical contact cleaner. i removed the fused sprayed it and plugged and unplugged the fuse a few times. The high beams have always worked and are still working. When I leave the lights on, on high beam or low beam, and then unplug and replug the fuse I can hear the relay clicking off and on. I wired one of the bulbs to the battery. Both beams work. Since the high beams work does that indicate my grounds are good? Does the relay engaging indicate a good fuse and relay? Does this whole scenario indicate a bad high beam low beam switch? thanks.
Another headlight woes thread
Mine did the same thing and it turned out to be the high/low beam switch inside of the steering column. (small button pushes in to switch between high/low and that button was worn out.)www.cardomain.com/id/jermnc77
Madness Committee Member & Contact Person
www.festivamadness.com
Festiva Madness
Snoopy's
4621 Atlantic Ave
Raleigh, NC 27604
it's that, OR, the relay, although clicking, may have a bad or dirty main contact. the actuator will still make it click, but the current can't pass through the relay. IF the relay always clicks when the lights are switched to the ON position, thats a good indication that the multi finction switch is still good, so suspect the relay.Trees aren't kind to me...
Originally posted by neanderpaul View PostSo is it a 2 part relay? The high beams never glitch..
To answer your question.The "Headlamp relay" supplys power for Brite/Low beams. It does this before it even gets to the "Multipositionswitch".
The "Parking Lamp relay" supplys power for the "Parking lites".It also does this before the "Multipositionswitch".Two seperate relays,with two seperate fuse's supplying them power.
Me thinks you have a bad "Multipostionswitch".When you switch from Brite too Low.The "Headlamp relay" doesnt even know this happened.As soon as you turn on the headlights, that relay is hot.It stays hot when you go to High Beam. You see what I'm saying? Normally I would suspect the "Fuseable Link Block" because its such a crappy design being exsposed to all the elements. But if it was the problem you would have the same issue with Hi Beams as well.(And you are not ,right?)And I would think your symptom would be compounded because your pulling even more amps with High Beams. The easiest way to narrow it down... Get a "Headlamp Relay" from a parts car,and install it. See if it goes away, I'm betting on the "Multipostionswitchagizzmo" being bad. But I always lose in Las VegasPeace-
Last edited by nitrofarm; 12-01-2011, 11:02 PM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
"Earth Angel" is right up my alley! I have looped it before. I'll have to get that one together again and catch it on video. GREAT song!
I have another high beam low beam switch. But it's from an 88/89 and I believe they are different. Another wire iirc. Of course it has orange type too. Maybe I can pull just the switch part. Thanks!youtube.com/neanderpaul 88 festiva LX w/BP G25 MR 5 speed waiting for wiring- 93 Festiva GL auto w/ air, waiting for B6t/G4A-HL - 98 Nissan Quest - 02 Mazda protege 5 wife's DD
Try the relay first
Originally posted by neanderpaul View Post"Earth Angel" is right up my alley! I have looped it before. I'll have to get that one together again and catch it on video. GREAT song!
I have another high beam low beam switch. But it's from an 88/89 and I believe they are different. Another wire iirc. Of course it has orange type too. Maybe I can pull just the switch part. Thanks!Some people like to read fiction,I prefer to read repair manuals. Weird I know-
MULTIPOSITIONSWITCH
Originally posted by jbuck1975 View PostWhen I turn highbeams on they Go out. If I flash them they are high.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Try spraying WD-40 into the switch. While you're at it spray some into the ignition keyhole. Fixded a problem I was having with wipers and lights going out randomly. Problem reoccured last summer and another spray put an end to it.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Originally posted by jbuck1975 View PostSometimes my ignition gets stuck and parking brake light stays on and wipers won't work. Turn key back and all is good.
EVO deck'd out with Bruce LeeSome people like to read fiction,I prefer to read repair manuals. Weird I know-
I just got my first festy, a teal 92 5spd.
Mine is doing the same thing, sort of. At first it was the fusible link, we swapped the link from the EGI and just turned on the lights and they came right on but after turning them off and on again only the high beams worked. I have a fused link fuse holder we made stuck in there now so it is a easily replaced fuse so that is no longer and issue.
Then we thought it was the relay but it still clicks on an off when the fuse is attached/detached. We checked the relay while it was working, when the lights randomly shut off while we were testing the wires, one of the always-hot wires went dead, I assume its the one to the low beams as they stopped working.
So the fuse is fixed, and the relay is working, last thing to test is the switch.
I will try the WD-40, or could I try PB-Blaster, or even just brake cleaner? And post results later.~Zach
