I finally got to endure my first drive in my b6t swapped festiva and im having a couple problems, my main concern is that when i drive in it my AFR goes all the way lean past 17.0 but will idle and cruise at low rpm's with the AFR at around 12.7. I have been adjusting my vaf spring and tps but so far have not had any luck in resolving this problem. Any ideas as to what the issue might be?
Edit: ECU is rocketchipped
