i just replaced the fuel pump because i wasnt getting fuel pressure. apparently the fuel pump wasnt the problem, i go to start the engine i hear the starter engaging but engine dont start so i pull the fuel line going into the engine and it has no pressure its dry. what is my problem anybody know?
Engine Wont Start
what year is the car.....did you check the fuel cut out switch under the rear drivers side speaker?"FLTG4LIFE" @FINALLEVEL , "PBH"
Should be able to turn the key and see if it makes a clicking sound. Can you hear the pump run when you turn the key on?89 L, hopefully returning from the dead soon with a little more power... :twisted:
front side of left strut housing, 3 little wires in a plastic holder.
they have slip on connectors and little wires instead of fuses.
they pretty much power everything that matters.
check them carefully for corroded or burned slip on
or wire burned inside insulation.Reflex paint by Langeman...Lifted...Tow Rig
Need to find out if there's power at the pump. If there's not, then I'd check for power at the relay. +1 on the fusible link things too, those will mess it all up.89 L, hopefully returning from the dead soon with a little more power... :twisted:
